What Tools come with the XL semi assembled 5T for use in assembly
Isolation Alaska
(@isolation-alaska)
Greetings from North Pole Alaska,
I ordered a 5T for Black Friday/my upcoming retirement on Dec31st, the semi assembled version. I was wondering what tools come with it for assembly such as allen and other wrenches and their sizes, screwdrivers , etc, so I can put together a premium toolkit for its assembly, as I have read that the supplied tools leave a bit to be desired, so I thought I would be proactive and ask you folks that already own them and have said tools, what they are. I live 2 miles from Santa Claus' house, so if you help me out Ill put in a good word from you 🙂
Thanks in advance for any and all replies. I bid you happy holidays!
Napsal : 03/12/2025 6:03 pm
Bryan Leister
(@bryan-leister)
RE: What Tools come with the XL semi assembled 5T for use in assembly
A bunch of allen wrenches, a phillips head screwdriver (which was never used), needle nose pliers (never used), and a bunch of torx that were never used. A couple of multi-tool wrenches which were used slightly. A torx screwdriver that I used a lot. I'm not sure what premium tools you would need, they all worked fine for me. The 3D printed torque tool was kind of unique. I assumed it was not to over-tighten, but I think it was to make sure people tightened the thing hard enough!
It was a pretty straight-forward assembly process and the prints are coming out great! Much better than the last printer I tried to install, a maker-bot about 15 years ago that never worked and turned me off from 3D printing for all that time. Also just retired and you'll have a good time with this! I got the 2T version. Only issue was learning about changing filament and what to do when it doesn't release properly. Found a video and ChatGPT is your friend here!
Napsal : 05/12/2025 12:27 am
1 lidem se líbí
ssmith
(@ssmith)
The assembly manual is online, it's good reading while you wait. Be sure to look at the comments for each section.   Section 3 has the tool list. The t10 driver is good enough, but torx drivers and hex drivers will make some things easier.
Napsal : 05/12/2025 4:45 am
1 lidem se líbí
Isolation Alaska
(@isolation-alaska)
Thank you kindly, thats just what I was looking for. And the guide link as well, I saw it once and then forgot about it. I will indeed read it ahead of time, The XL is shipping next week. Thanks again!
Napsal : 05/12/2025 6:19 pm
1 lidem se líbí
