Tpu printing issue please help
Bartp
(@bartp)
Hi everyone, Please help — I can’t figure out what’s causing these print errors in my slicer. The filament is Sunlu TPU, brand new out of the box (so it shouldn’t need drying). I’m using a 0.8 mm nozzle, with a layer height between 0.2 and 0.35 mm, and a print speed around 25 mm/s. No matter what I try, I can’t get a clean print without these failures — the issue always appears in one corner.
Any advice or suggestions on what settings I should adjust would be greatly appreciated!
Posted : 10/10/2025 2:24 pm
Whilst I suspect you do have a geometry problem in the corner it is being magnified and masked by moisture; never assume new filament is dry.
Dry your filament and try again.  If problems persist first try rotating the print on the bed - if the problem moves with the print it is probably something in the file/settings, if it stays in the same position relative to the printer it may be a cooling issue.
If it seems to be a file issue save your project as a .3mf file
Files > Save Project as
Posted : 10/10/2025 4:15 pm
John Lindo
(@john-lindo)
RE: Tpu printing issue please help
I agree with diem.
Post the STL and I will also give it a test.
What are you auxillary fan settings ?
From the photos it looks like an air vent of some kind, so why TPU ?
I have had good success with carbon impregnated filament for these type of prints. Recommend ZIRO.
Cheers,
Posted : 10/10/2025 5:10 pm
John Lindo
(@john-lindo)
Also orientate the part 45 degrees on the bed, it could also be a belt tension issue, if OK
then if it is still an issue, flip the print over on the heater plate, vents look 45 degrees so no different geometry issues.
Cheers
Posted : 10/10/2025 5:17 pm
