PrusaLink Issue with 6.1.2 - constant having to reset the printer
joshuaj99
(@joshuaj99)
Utenti
Anyone else having a problem with Prusa Link and the latest firmware?
Prusa Link generally worked prior to the upgrade, only some occasional issues. Now I only can upload one file and then I have to reboot the printer. After the first upload I get a timeout error trying to send the files from Prusa Slicer.
Postato : 21/11/2024 3:44 am
Scisok
(@scisok)
RE: PrusaLink Issue with 6.1.2 - constant having to reset the printer
I recently had the same problem.  It turned out that somehow the printer had a new IP address that was 2 digits off from the correct one.  I use a static IP address (from my router) for the printer so it never changes.  After a reboot it came up with the correct IP address.
Postato : 22/11/2024 7:08 pm
joshuaj99
(@joshuaj99)
Utenti
Thanks for the info.
I've always had my printer assigned a static IP at the router so I could use the PrusaLink web UI to check on it before Prusa put that in the slicer. Never had a problem with the networking, though perhaps something with the firmware update has changed that.
Postato : 24/11/2024 5:51 am
