printer dimensions without side spools
Stated print volume & dimensions are:
Build volume: 360×360×360 mm (14.17’’×14.17’’×14.17’’)
Printer dimensions: 800×800×900* mm (31.49’’ ×31.49’’× 35.43’’)* including side spoolholders and top enclosure cover (separate future add-on)
If you have the spools below the printer (e.g. Repkord box), what can you get away with? Assuming the depth is the same, but width can be reduced?
Opublikowany : 14/08/2023 4:10 pm
I plan to move some of mine above the machine - but the guide tubes are mounted on the sides, they might be movable and you'll need to be able to get at the sides for access/maintenance so you won't get all the space back, perhaps 100mm per side max/
Opublikowany : 15/08/2023 4:16 am
