Nextruder Enclosure Buzz
I finally tracked down this loud buzz I'd get from time to time to the printed panels on the Nextruder.
Is this a known issue?
RE: Nextruder Enclosure Buzz
I don’t get a buzzing, but I’d sure like to see what yours does. The vid doesn’t look like it uploaded.
Hmm, Not sure what I did there. Here is the video.
Hello,
I had a similar buzzing noise, it was very hard to locate.
As I see you also have 2 tool heads...
Check the metal profile which the docks are attached to. In my case, the profile vibrated inside the aluminum extrusion.
I fixed it with a spare M3 screw and tightened the profile where the 5th dock would sit.
I have a 5T. I've mostly been using tools 1 and 5. Tool 1 is quiet, tool 5 has this buzzing issue. So I suspect there is something to do with subtle differences in assembly or the tolerance of parts in the nextruder. I plan to look into this more when I have time - it's useful to have both quiet and noisy tools for comparison etc.
