measurements for xl structure 5 extruders
Pier3D
(@pier3d)
Good morning everyone, I wanted to know if any of you have created a structure for an XL5 extruder... I need to know what size the base must have... considering that the coils are placed on the sides... and if you have some photos, thanks
Postato : 16/02/2024 11:43 am
EastMemphis
(@eastmemphis)
RE: measurements for xl structure 5 extruders
I published a fairly detailed model of the XL that may be of some use.
https://www.printables.com/model/762684-prusa-xl-model
Postato : 16/02/2024 2:15 pm
Pier3D
(@pier3d)
Thank you but I didn't mean about enclosures... but about space if I have to make a table
Postato : 16/02/2024 4:24 pm
EastMemphis
(@eastmemphis)
The model is of the XL itself. It can be used to derive the measurements quite easily.
Postato : 16/02/2024 4:37 pm
Pier3D
(@pier3d)
Where did you place it?
Postato : 16/02/2024 5:24 pm
EastMemphis
(@eastmemphis)
It's a model in Printables. I already supplied the link.
As far as table size, it's a fairly large unit and consumes about a 2'x2' square (600x600mm). I think one of the most important things about your support structure (aka table) is that it's extremely heavy and sturdy. The XL moves a lot of mass around fast so the forces imparted to the table are significant. Damping out those motions with a heavy and sturdy table will result in better printing results and finer details.
My table moves too much and weighs in at around 250 lbs (100kg) and that's not enough.
Postato : 16/02/2024 5:34 pm
