layer shifts when using .25mm structural
JuanCholo
(@juancholo)
kind of interesting...
I'm using .4mm nozzles and have a very large print so I decided to try out .25mm structural layer heights on the XL.
print started off fine, so i left it for a few hours. it layer shifted left over 10mm. interesting.
i checked everything and decided to try out a test print of a tall tower, it layer shifted as well.
this is the first time i had seen my XL layer shift as i have been using .15mm layer heights for the most part.
took the same test print tower and ran at .2mm and no layer shifts.
G-code looks correct so I'm going to say something is again up with the firmware.
So i restarted my first large print at .2 instead of .25mm layer heights and knock on wood over the last 12 hours it has not layer shifted.
i guess just something to look at if it happens to you. i have no experience with the .6 nozzles and thicker layer heights you can do with them.
“One does not simply use a picture as signature on Prusa forums”
Napsal : 27/03/2024 5:16 pm
JuanCholo
(@juancholo)
RE: layer shifts when using .25mm structural
a little update...
so when i tried out .25mm layer mode with in 2 hours i had 3 print failures due to random layer shift.
in .2mm layer mode i have gone 2 days without a single layer shift issue and i have done 3 prints over 10 hours long. the last print ran for 18 hours no problem.
just another issue to be on the look out for.
Napsal : 30/03/2024 2:36 am
