Issue with Belt Rubbing on Prusa XL
mitsol
(@mitsol)
Membre
Hi everyone,
I’m reaching out for help or opinions regarding my Prusa XL Dual. I’ve encountered a problem where the belt at the rear near the extruders is rubbing against a screw. To make matters worse, the belt seems to run directly over this screw.
Initially, I didn’t notice this issue, but I started having continuous print problems. After some troubleshooting, I discovered that the belt was already heavily damaged from the rubbing. When comparing with another photo I found online (look at this post: https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-general-discussion-announcements-and-releases/tool-crash-problem-fixed/), it seems like these screws are positioned much higher on other machines.
I’m confused about how this could happen. Did I miss something during assembly, or could this be a manufacturing issue?
Has anyone else experienced this? I plan to contact Prusa support, but I’d love to hear if someone else has faced and resolved a similar problem.
Thanks in advance!
Publié : 29/12/2024 9:41 pm
There should be clearance between the belt and the structure.  To confirm the rubbing point(s) cut a strip of paper and hold it between the belt and nut/bolt end while the belt is moving.
Try to establish the extent and length of damage to the belt, look for short sections with excessive wear or is the damage roughly even throughout its extent.
My first suspicion is a collapsed pulley bearing - you may hear grating noises from one corner ...
Yes, contact support by chat, the first thing they will ask for is the serial number on the back of the machine.  Be ready to supply photos, video, and possibly audio files.
Good luck, let us know what is/was the cause.
Publié : 30/12/2024 6:24 am
mitsol
(@mitsol)
Membre
RE: Issue with Belt Rubbing on Prusa XL
Thank you for your answer! I'm already in contact with the support team. However may it be possible for someone of you to send a foto of how much space should there usually be between the belt and the tools on the backside?
Thank you
Publié : 02/01/2025 10:39 pm
I don't want to disassemble but this should give you some idea:
Publié : 03/01/2025 10:38 am
DavidThePurple
(@davidthepurple)
Membre
This solved it for me.
Thanks Sebastian!
Publié : 02/04/2025 1:43 am
