Idler lever lock PSA
Hey everyone just a short PSA for you. If you have a difficult time with getting a good first layer or if your nextruder just quits extruding check to make sure the idler lever is tight. Both times I had a under extrusion issue the bolt and nut were loose allowing the lock to loosen just enough to create enough play so that the filament would slip.
Veröffentlicht : 27/08/2024 7:37 pm
