[Risolto] How to replace thew PETG core xy parts Prusa XL
benjaminbacon
(@benjaminbacon)
Utenti
Hi everyone,
Sorry if this has been answered before but I have looked and couldn't find an answer. I have a XL that was purchased before the upgraded O rings and PCCF updates for the originally shipped PETG core xy parts. I recently recieved the XL enclosure and before I install that, I would like to update the O ring and core xy parts. Could someone direct me to the best installation instructions for those parts?
Thanks!
Best Answer by benjaminbacon:
Hi everyone,
Found the right manuals via Prusa help chat. For anyone else looking for instructions, These are the best:
The enclosure upgrade guide does cover some of the parts: https://help.prusa3d.com/guide/3-printer-upgrade_668674
But for the full core xy, the best option would be this guide: https://help.prusa3d.com/guide/how-to-replace-the-tch-profile-insert-xl_639940
Thanks!
Postato : 24/09/2024 10:46 pm
benjaminbacon
(@benjaminbacon)
Utenti
RE: How to replace the PETG core xy parts Prusa XL
Hi everyone,
Thanks!
Postato : 25/09/2024 4:47 pm
2 persone hanno apprezzato
LewnWorx
(@lewnworx)
RE: How to replace thew PETG core xy parts Prusa XL
Was about in the same boat.
I had to replace the sandwich board to bed control cable (as prusa had swathed it during the core xy assembly at the factory which cause boatloads of heatbed issues at high temps) and I’d already had problems with the idlers on the extruders and some other PETG parts, so I printed all the core XY stuff in PCCF and figured I’d replace all those during the cable swap as I was already having to a huge tear down anyway.
As there is no guide for replacing the cable in question, like you I found the same guide was probably the closest I would find as an official prusa doc on how to do it.
What I found is the CORE XY carriage stuff  was already PCCF, but the core xY tensioners were PETG.      Apparently these changes have been getting gradually phased in.
So I did swap out the tensioners.   There’s also two little parts that hold the dock rubber band things in place for each extruder that were also PETG vs PCCF.  I’ll do those next weekend.
It’d be nice if they actually had a dedicated guide for the CORE xy stuff.
Postato : 15/10/2024 1:52 am
Jeremiah
(@jeremiah-2)
Does anyone know if the CoreXY Parts sold by Prusa are in PCCF now? There is no indication of what material was used.
Prusa does state that the Nextruder and Belt Parts are printed in PCCF.
How do you visually identify what is PETG vs PCCF?
Postato : 05/11/2024 6:39 pm
Ro3Deee
(@ro3deee)
Posted by: @jeremiah-2
color (PCCF are grayish)
Postato : 29/12/2024 11:32 pm
kaanivore
(@kaanivore)
If I got a Prusa XL in November 2024, does it need any additional parts to be replaced or can I assume that all the relevant ones are PCCF?
As far as I can see the most obvious ones are in PCCF like the tensioner, hotend parts right near the hotside, and CoreXY motor mounts, but there's still a bunch of PETG like the X-carriage cover (I can't see the belt holders but will check), toolhead covers, CoreXY Extrusion end caps etc.
I'm running the EnXlosure so didn't get any parts to swap in, need to do it all manually.
Postato : 09/01/2025 6:44 pm
kaanivore
(@kaanivore)
Looks like the belt clamp itself is ok per step 51, but the rest of my question still stands
Posted by: @kaanivore
Postato : 09/01/2025 6:45 pm
Brian
(@brian-12)
According to the instructions if yours was built after June 2024 your good.
Postato : 09/01/2025 10:15 pm
