Easy way to print with tool #2
DarrenHumphrey
(@darrenhumphrey)
Right now tool #1 is jammed and not working. While I try to figure that out, I'd like to keep printing using tool #2. It's not practical to go into the slicer and paint all the geometry for tool #2. Is there a way in the firmware to override which tool it's going to use for a print? Otherwise I am dead in the water until I can get tool #1 working.
Napsal : 04/12/2023 5:03 pm
Maikuchannn
(@maikuchannn)
RE: Easy way to print with tool #2
In PrusaSlicer, on the right side of the window, there is a section that lists the objects loaded on the print bed, directly underneath the infill percentage.
To the right of the object name is a column that says "Extruder".
The extruder is normally set to "default", which I believe defaults to extruder 1, but you can click on the default extruder, which will open a dropdown menu and allow you to change to your desired extruder.
Napsal : 05/12/2023 3:47 am
DarrenHumphrey
(@darrenhumphrey)
I just updated the firmware and I now see that I can override which extruder to use at print time, which is what I wanted. I didn't want to have to reslice a file to use extruder #2.
Napsal : 07/12/2023 7:44 pm
