Does a Better Cable Clip Exist?
KCPens
(@kcpens)
Is there a cable clip design that puts the sleeve of wires that run the nextruder directly overhead of the connection?  I added the connector support to stabilize the wires/connector but still would get periodic erroneous extruder errors.  I ended up bypassing the black support thing between the bowden tube and the wire harness on the clip nearest the nextruder and turned it 180 degrees so the wrapped wires are directly inline with the connector.  So far it seems to be working better and the wires are no longer bent 90 degrees+ to get to the nextruder.
Prusa XL abgerundete Kabel Clip zum Extruder / XL rounded cable clip to extruder by Bernd | Download free STL model | Printables.com
Napsal : 03/12/2025 8:30 pm
