Different nozzle sizes in the same print
Robert
(@robert)
Is there a possibility of using different nozzle sizes in the same print ? Looks the slicer is always using the same line width even with extruders set to different nozzle sizes (0.25 / 0.8 mm). If no direct solution, is there any workaround (with e.g. custom gcode) available?
Does xl firmware support different nozzle sizes for the same print so a different slicer can be used?
Publié : 17/02/2024 1:26 pm
BaconFase
(@baconfase)
RE: Different nozzle sizes in the same print
GUIDE: How to print with multiple nozzle sizes
If you want extra workaroundness in your slicer: Fork of PrusaSlicer that enables wipe tower for mismatched nozzle sizes - HIGHLY experimental
Publié : 19/02/2024 8:46 am
1 personnes ont aimé
polydisco
(@polydisco)
Is there any update if & when Prusa Slicer will support this?
Simplify does the job, Slicing preview looks perfectly fine and I had succesful prints,
However it's buggy due to probably not being perfectly optimized for the XL  toolheads and gcode commands.
Publié : 21/10/2024 8:00 pm
