Change filamant change position
Hello everyone,
I wanted to ask if it is possible to change the position of the filament changer on the Prusa XL. I occasionally print objects with the sequential function of the Prusa Slicer, but unfortunately I always have to check beforehand whether there is enough filament available. If I run out of filament while printing the last part, for example, the filament change would be triggered and this always happens at the front left, which of course causes the X-axis to collide with the elements that have already been printed. I would therefore like to move the filament change position to the back left so that I can also use the Filamanet runout function when printing one after the other.
Unfortunately I have not found such a possibility so far, do you know a way or would I have to make a FeatureRequest on GitHub?
BR
Manuel
