Can the tool head change automatically when filament runs out on one head?
Pvets
(@pvets)
Utenti
When the filament runs out on one head, is it possible to change automatically to another head?
Postato : 06/08/2023 1:15 am
We won't know for certain until someone tries it but the SpoolJoin function is standard on the MMU - all versions, so it's reasonable to expect it to be carried over.
Postato : 06/08/2023 11:31 am
Westranm
(@westranm)
RE: Can the tool head change automatically when filament runs out on one head?
I was told by support that such a feature is planned for a future firmware upgrade.
Postato : 16/08/2023 2:53 am
Tobycwood
(@tobycwood)
No.
Posted by: @pvets
Postato : 20/10/2023 10:53 pm
CHUCKD
(@chuckd)
Utenti
Yes, the spool join function is in the new alpha firmware 5.1
Postato : 22/10/2023 1:28 pm
1 persone hanno apprezzato
xilni
(@xilni)
Posted by: @chuckd
I’m really surprised they didn’t explicitly call this out in their blog when it’s clearly called spool join in the menus.
Postato : 23/10/2023 1:31 am
ByteC
(@bytec)
I think it is more or less mentioned under
Pre-print screen (XL Multi-Tool)
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases
Seems you can map multiple extruders to one material...
Postato : 23/10/2023 4:31 pm
Tobycwood
(@tobycwood)
I went ahead and installed the alpha fw as well as the matching ps preset. I don’t get that screen in the preprint view. I do get a similar screen that seems to let me remap which extruder to use, but that does not function correctly. So the answer to the OP for now is… no.
Postato : 26/10/2023 9:06 pm
GuyH
 GuyH
(@guyh)
There's spool join in the new alpha FW
Posted by: @tobycwood
Postato : 26/10/2023 9:12 pm
Tobycwood
(@tobycwood)
Ok… where? I looked in every menu. I don’t see it.
Postato : 27/10/2023 9:06 pm
GuyH
 GuyH
(@guyh)
When you start a print and can change the colours/tool, click to change one to another tool/filament and it gives the option to spool join. I've not tried it yet.
Postato : 27/10/2023 9:22 pm
Tobycwood
(@tobycwood)
Nope… when you select Change, it activates the material type and you can cycle through the different types. There’s no means there to couple spools. Nothing.
Postato : 28/10/2023 3:16 pm
GuyH
 GuyH
(@guyh)
Don’t click on change, scroll on to one of the tools/colours and click, I think it gives the option then. I’ve a print going all day so I can take photos once that’s done if helpful
Postato : 28/10/2023 3:58 pm
Tobycwood
(@tobycwood)
Yeah… I finally found the dang thing.  It wasn’t easy.
select the print and you get the screen that shows the gcode filaments on the left and printer tools on the right. Rotate the knob past the buttons and the gcode filament on the left is selectable. Select it, then you can select a printer tool. Select a different printer tool and finally you’ll see a new screen with a spool join button on the bottom.
Postato : 28/10/2023 4:49 pm
2 persone hanno apprezzato
Tobycwood
(@tobycwood)
I’ll test it and report back.
Tobycwood
(@tobycwood)
It worked Perfectly!
Postato : 28/10/2023 6:04 pm
3 persone hanno apprezzato
Huin Jean-Paul
(@huin-jean-paul)
Utenti
I'm glad to hear that. I had installed an MMU on one of my two MK3s just for this function, so that I could use the reel backs. It would have been a real shame if the XL hadn't been able to do this.
Postato : 31/10/2023 8:47 pm
