Can I use 3D Lac on the satin powdered sheet?
C3D
 C3D
(@c3d)
So I recently received my Multitool XL and I havent used a satin sheet before.
Its great but has to be cleaned often and I was wondering if I can use 3D Lac on it?
I do a lot of production and the additional safety Lac provides helps with failed prints due to warps, especially on big models.
Glad to be part of the Prusa team btw!
Postato : 22/08/2024 11:17 am
Acht
 Acht
(@acht)
Hey,
I am also a fan of 3d Lac. No issue with that. Just remember to spray it far away from the printer. You don't want to get into the rails and so on.
I really does help keep the print on the bed and the bed safe. It might not always be needed, but is sooo reliable.
Postato : 22/08/2024 1:52 pm
1 persone hanno apprezzato
Artur5
(@artur5)
I concur.
3DLac is your best friend, whether is a smooth, satin or textured sheet.  Specially useful for PLA on the satin/textured sheets if you're printing models having a small contact area with the bed and/or steep overhangs.
Questo post è stato modificato 2 years fa da Artur5
Postato : 24/08/2024 7:19 am
C3D
 C3D
(@c3d)
RE: Can I use 3D Lac on the satin powdered sheet?
Thanks guys. I do use Lac on all of my other machines (10 of them) but i never owned a satin sheet before. Since Acht's reply i've been using the lack on the XL Satin sheet and it works flawlessly.
Thanks a lot, glad I can keep using it!
Postato : 31/08/2024 6:44 pm
