6.4.0-alpha Firmware for Prusa XL
Seite 1 / 2
Jan Kratochvíl
(@jan-kratochvil)
Mitglied Admin
Summary
  • New features
    • Belt tuning wizard (C1)
    • Faster and more responsive Prusa Connect experience
    • Auto-retract (MK4, alpha for XL)
    • Selective factory reset
    • Chamber support for backwards G-Code compatibility (C1)
  • Changes and improvements
    • Improved print status messages
    • Lazier homing, more cautious calibration
    • Autoload improvements
    • Unified XL & CORE One chamber filtration
    • Option to continue after nozzle cleaning failure
    • Print sheet detection (MK4)
    • Respect maximum printed Z position
    • Gearbox alignment calibration (XL)
    • Filament change from Tune menu in any tool (XL)
    • Support cancelling more objects
    • Wi-Fi signal strength indicator
    • BSOD knob press behavior
    • Reworked filament sensor evaluation
    • Ukrainian language support for all printers
  • Fixes
    • Purge option on nozzle cleaning failure
    • Disable print fan during filament change
    • Various layer shift fixes
    • All the fixes from the 6.3.X releases have been expanded to other printers.
    • Bunch of more fixes.
This is the alpha release for the upcoming firmware 6.4.0 for the Prusa CORE One, MK4S, MK4, MK3.9S, MK3.9, MK3.5S, MK3.5, MINI & XL. It reunifies the firmware development branch after the temporary split during the CORE One launch, where 6.3.x was released exclusively for CORE One and other printers remained on 6.2.x – along with bringing new features, improvements, and fixes across all platforms. While marked as an alpha, this release maintains the stability and security of existing printer features.
A new guided wizard has been added to the Prusa CORE One to help users properly tension the X/Y belts. The printer uses controlled belt excitation combined with stroboscopic feedback to visualize belt resonance, making the tuning process more intuitive and reliable.
The wizard, accessible via Settings → Manual Belt Tuning, begins by prompting the user to check that the gantry is properly aligned, as misalignment can affect measurement accuracy. A quick manual alignment can be done by loosening both tensioner bolts, gently straightening the gantry by hand, and re-tightening the bolts evenly while keeping the gantry square. More information about gantry alignment can be found in this article.
The wizard then measures the vibration frequency of both belts and recommends whether to tighten or loosen them. The target frequencies are 96 Hz for the upper belt and 92 Hz for the lower belt.
NOTE: A difference of up to 8 Hz between the belts is acceptable, as long as both values remain within the 90–98 Hz range. If values cannot be reached, the wizard will suggest manual squaring before continuing.
If your gantry is out of alignment, you may not be able to reach these exact values. In some cases, the lower belt can even show a slightly higher frequency than the upper belt.
NOTE2: Since the in-depth article on using the Belt Tune Wizard is still in preparation and will be published together with the stable or RC release of this firmware, all QR codes currently point to these release notes.
Communication between the printer and Prusa Connect is now handled using WebSockets, replacing the previous polling-based method.
While this change does not affect raw data transfer speed, it significantly improves overall responsiveness and interaction with the cloud service. Users can expect (via Prusa Connect):
  • Lower latency when starting prints
  • Faster execution of remote commands
  • Smoother and more fluid control during cloud-based workflows
This update also lays the groundwork for future enhancements to remote monitoring and control by the user, allowing for continued improvements to the connected experience in future releases.
Auto-retract (MK4, alpha on XL)
The auto-retract feature is now enabled on MK4 and XL printers, after its first introduction on CORE One in firmware 6.3.X. Filament is automatically retracted from the nozzle at the end of each print, which helps reduce oozing during bed leveling and removes the need to preheat the nozzle when unloading.
On the XL, the feature is currently available only as an alpha preview - at this stage, the printer retracts only the active tool after a print. We are working on further improvements, with the final version planned for the 6.4 release.
NOTE: Auto-retraction is not applied to flexible filaments; to handle these, we have added a new “Is flexible” parameter, configurable in filament presets via the printer’s GUI or using the M865 G-code.
We have introduced more granular control over the factory reset process. Instead of wiping all data at once, settings are now divided into categories, allowing you to decide what to reset and what to keep. These categories include:
  • Calibrations: All the calibrations data and selftest results
  • Common misconfigurations: Quirky settings that might cause unexpected behavior if you don’t know about them, for example disabling filament sensors, changing steps per mm
  • Network: Wi-Fi, Ethernet, Prusa Connect, PrusaLink related items
  • User interface: Items that affect user interaction with the printer – language, sound settings, footer settings, touchscreen, LEDs, and so on
  • Stats: Print & error statistics
  • HW configuration: Items that are linked to the hardware installed on the printer: nozzle diameters, extruder type, (also) steps per mm, printer type,...
  • Printer functions: Configuration of various print functions, such as MMU, chamber filtration, HW checks,...
  • User profiles: Custom filaments, print sheets (MINI and MK3.5)
To simplify the process, we have also prepared several reset presets for the most common scenarios:
  • Ownership transfer: Useful when you’re giving the printer to someone else. Will reset all your personal settings such like network and filament profiles, but keep things like hardware configuration, calibrations and statistics.
  • Fix common misconfigurations: This is what the support team will likely advise you to do during troubleshooting. Intended to fix things like filament sensor not working because it was accidentally turned off from the menu.
  • Keep HW config: Keeps only the hardware configuration (what nozzles, fans, extruders the printer has), nothing else. This reset is performed before shipping assembled units to the customers.
  • Full reset: Wipes everything, except for the firmware itself
  • Hard reset: Wipes everything, including the firmware. A USB drive with a new firmware will be needed.
If none of the presets fits your needs, you can start with the closest one and then manually adjust each category to reset or keep it according to your preference.
When printing on the CORE One in compatibility mode using files sliced for the MK4 or other supported printers, the firmware now automatically handles chamber temperature control. Since these G-code files do not contain the required commands for chamber heating or cooling, the printer applies chamber management heuristically. Previously, no chamber control was performed in this mode.
Status messages have been revised to provide clearer feedback during printer operations. They now give more detail about what is happening, show progress where applicable, and remain visible until the operation is completed instead of disappearing after just a few seconds.
NOTE: They also do not disappear when the print is paused, which addresses the issue #3143
Homing behavior on the XL and CORE One has been refined to avoid unnecessary movements. In cases such as filament load or unload, the printer now performs only basic homing, skipping the extra diagonal movements. If a precise position is required later, only the refinement step is executed. For unload operations with auto-retraction, homing is still performed to ensure the correct filament removal angle.
This change applies only to specific situations—G-code G28 without parameters, which is placed at the start of every print, will still trigger a full homing sequence. We are also considering updating slicer profiles in the future to allow optional homing.
In addition, the long and noisy precise homing calibration is no longer run automatically. Instead, the printer now checks reliability and suggests the calibration only when needed, and you can always choose to skip it. If required, the precise homing calibration can be started manually at any time from the Calibrations menu.
The autoload process has been refined to make filament changes faster and easier. Printers now begin preheating the nozzle to 170 °C as soon as the load procedure starts, without waiting for the user to confirm the filament type. On printers equipped with a side filament sensor (CORE One, XL), the procedure also starts automatically when filament is inserted into the sensor. In this case, the toolhead moves to an optimal position for feeding filament through the PTFE tube, and the extruder begins spinning to assist insertion.
NOTE: On the XL, the relevant tool still needs to be selected before autoload is triggered.
Additionally, the printer now checks whether the extruder filament sensor is already active when filament is inserted into the side sensor, warning the user in case debris or leftover filament is present in the printhead.
We have unified the code for chamber filtration between the XL and CORE One, so both printers now share the same features. As a result, the CORE One gains all functionality previously available on the XL, and vice versa.
In addition, several new options have been introduced. You can enable Filter all materials to keep filtration running regardless of filament type, and the Filter usage counter can now be adjusted manually for your own convenience.
We have also added two new G-codes: M147 (set) and M148 (unset), which let you explicitly mark whether a print requires filtration or not, overriding the automatic behavior based on filament parameters. (#4480)
If nozzle cleaning fails, the printer now offers an Ignore option, allowing you to continue with the print instead of being forced to abort the job.
The print sheet detection feature, originally introduced with the CORE One, is now available on MK4 printers. Before starting a print, the printer checks whether a sheet is installed and notifies the user if it is missing.
The firmware now tracks the highest extruding Z position reached during a print and ensures that toolchanges, filament changes, and parking moves are performed above this level. This prevents the toolhead from colliding with already finished parts during sequential printing (complete individual objects).
Gearbox alignment procedure is now available for the XL. We recommend running the procedure in the case that you needed to disassemble and reassemble the extruder.
You can now change filament in any tool from the Tune menu, not just the currently picked one.
Formerly, our printers were only able to control cancelling of the first 64 objects in the print file. This limit has now been increased to 1024.
NOTE: In the printer UI, you will still only see the names of the first 16 objects. The rest will be displayed as “Object X”.
The Wi-Fi icon in the header now displays signal strength, with individual bars lighting up according to the connection quality.
Pressing the knob during a BSOD no longer restarts the printer - it now only silences the beeper. To restart the printer, use the dedicated Restart button.
The evaluation method for the Nextruder filament sensor has been redesigned. This update improves reliability by reducing false runout detections and ensuring that actual runouts are correctly recognized.
Ukrainian language support, first introduced on the CORE One in firmware 6.3.3, is now available across all printers.
When nozzle cleaning fails, the Retry button now includes a Purge option. In this mode, the nozzle is heated to extrusion temperature, a small amount of filament is purged, and then an auto-retract is performed to prevent oozing during cleaning and bed leveling. The user is prompted to remove the purged filament, after which the nozzle cools back down to its cleaning temperature (typically 170 °C).
Multiple bugs related to layer shifts have been addressed. While some edge cases may still exist, layer shifts should now occur less frequently and affect fewer models.
Release notes
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.4.0-alpha
Dieses Thema wurde geändert Vor 5 months von Jan Kratochvíl
Veröffentlicht : 10/09/2025 6:05 pm
BullDog8484
(@bulldog8484)
RE: 6.4.0-alpha Firmware for Prusa XL
Several head crashes both at the beginning of prints or at the end of prints on both of my XL's.  Doesn't happen during a print just at beginning and end.  Recalibrated docks, calibrated homing, verified belt tension.  No change.  Can't reliably repeat the behavior.  Seems to be random.
Reverted back to 6.2.6 on one machine and it seems to have cleared up the issue on that one.  Will continue to test on the 6.4.0 alpha machine to see if I can determine a root cause.
Veröffentlicht : 15/09/2025 7:17 pm
3 weiteren Personen gefällt das
Nicholas Beach
(@nicholas-beach)
Mitglied
Same issue for me
Veröffentlicht : 16/09/2025 1:03 pm
Her MannF
(@her-mannf)
Same issue for me, Reverted back to 6.2.6 on one machine and it seems to have cleared up the issue on that one.
Veröffentlicht : 17/09/2025 9:57 am
BullDog8484
(@bulldog8484)
Rolling back to 6.2.6 on both XL's now.  I tried over 20 prints on the 6.4.0 machine.  Out of the 20 prints, I had 5 head crashes.  2 at the beginning of the print - both with toolhead #1, and three crashes at the end of a print - 1 with toolhead 1, 1 with toolhead 3, and 1 with toolhead 4.  The same gcode on the other XL with 6.2.6 printed flawlessly with no crashes.  Can't discern a pattern.  Prints were a mixture of small, medium, large - multi tool, and single tool.  Doesn't seem to matter.
The only thing I noticed is that with 3 of the crashes ( 2 at beginning and 1 at the end), the toolhead took extra-long to do the x-y homing sequence at the beginning of a print.  But there was one print that took longer with the homing sequence that finished fine - no crash.  The other two times it crashed, the initial homing sequence was fine so, I have to believe the homing sequence is not attributable.
I do like some of the new features in 6.4.0.  Especially the retract.  Looking forward to the RC or final versions and hoping they don't have the head crash issue.
Veröffentlicht : 17/09/2025 12:39 pm
John Katzman
(@john-katzman)
Mitglied
Completely agree with what those posted above. I've never had a single print head crash ever and this alpha release caused a ton of them. I was also hearing a loud click right before the tool would start a layer, like it was shifting or making a pretty large adjustment to snap the toolhead in, then a rough first layer would go down.
Steps I took to fix the crash were to recalibrate all 5 print heads FULLY, no change in crashes. Including the new gear adjustment calibration - DID NOT WORK
I have reverted back to 6.2.6 and crashes are gone immediately and prints go back to near flawless.
I did love the auto retract feature, really cleaned up the dribbles on the print bed!
Veröffentlicht : 26/09/2025 7:27 pm
Tow Truck
(@tow-truck)
Mitglied
While I really liked the improvements in 6.4.0 alpha, I have had the same issue listed above. For me the X-axis "mis-steps" (with a loud pop or bang) during the initial tool purge. It has happened on multiple tools at random times causing a crash when the tool is docked in the tool holder. If this occurs during purge, but the tool is used first, it will run the print fine until it's time to change tools, then it will crash.
The other issue I had was after running phase stepping calibration under 6.4.0 alpha. Both the X&Y axes got extremely loud and resonated badly. (I wonder if this is the reason my CORE One resonates?!)
After rolling back to 6.2.6 the "mis-stepping pop" was cleared up and re-running the phase stepping calibration quieted the machine right down again.
I hope Prusa gets this resolved as the new FW was a very good step forward otherwise.
Veröffentlicht : 26/09/2025 10:57 pm
Mafko88
(@mafko88-2)
Mitglied
I used version 6.4.0 for several days, and head crashes during docking were too frequent, so I need to downgrade the version to avoid unnecessary wear on the printer. However, I noticed that every print starts with a slight bump on the Y-axis, which I believe could cause the extruder position to shift. This misalignment might result in the extruder missing the correct docking position after printing.
Veröffentlicht : 01/10/2025 12:50 pm
Be Me
(@be-me)
I tried 6.4.0 alpha for a few days and this firmware is an absolute danger to your hardware. The most obvious problem are the head crashes, they just hit their dock at full speed when parking.
Then there is the motor sounds and failed phase stepping and input shaper calibrations. I thought my XL XY-gantry or motors are broken at this point.
Phase stepping calibration only reduced vibrations by 30-45% compared to 90%+ on older firmware. Input shaper calibration won’t even finish and says my belts are too loose for calibration - which they are not.
Went back to 6.2.6 and the only thing I am missing is the firmware auto retract that really prevents oozing. All problems and weird sounds are gone. Calibration finishes as expected.
I will not go to and 6.4 pre-release.
Veröffentlicht : 07/10/2025 5:39 am
siaulip
(@siaulip)
Same for me - homing errors, z-calibration errors, constant spontaneous rebooting, tool change crashes at random, carrier skipping steps resulting in shifted layers. Weird artifact on the front wall of homing tower, whereas the back X and both Y did not have any artifacts.  Skipping of the motor occurs at random - verified on printing manual calibration 10 times - occurred at random but results were visible very quickly by using that print file.
After downgrading to 6.2.5 no issues, calibrations went also without any errors whatsoever. Weird artifact on the front wall of homing tower is also gone. There is a major bug in the alpha release unfortunately...
Veröffentlicht : 08/10/2025 8:25 am
Michael Hale
(@michael-hale)
Mitglied
Not to pile on, but I also experienced head crashing with 6.4.0 alpha.  It's surprising this release made it out of initial quality assurance 🙁
Veröffentlicht : 09/10/2025 1:43 pm
Bdbtoys
(@bdbtoys)
I noticed... if the print head is already sitting at the homed position, it seems to slam across the left front rail (looking at the front). This happened both before and after doing the home calibration.  That slam can't be good. I originally took this machine for the print head filament detection issues... but hearing what others are saying, I may want to revert.
Also, I have seen calls for this in the past... but can we please merge the XL Single/Multi forums? It seems silly to have 2 especially on these types of posts.
Veröffentlicht : 12/10/2025 4:28 pm
Chase York
(@chase-york)
Wanted to add my experience as well, in case it helped at all.
I have two 5TH XLs, one testing the pre-release and the other on the main release. This alpha release has caused the same problems on only my multi toolhead prints. Most of the last two weeks I didn’t experience any issues at all after updating. But I was running mostly single toolhead prints. Howver, even my first few multi toolhead prints went fine. But they eventually began resulting in docking crashes and layer shifting. But I found a temporary fix of sorts.
First it occurred at the end of a print. Then it started happening at every tool change. Stopped the print and retried it, same thing. Resliced it. Same thing. Tried it on XL number two, printed fine. So I recalibrated the toolhead that I was affected, no change. Yadda, yadda. Same story as everyone else. The layer shifting and stuff was giving me the impression that it was losing home position or skipping steps somehow, which was causing the eventual dock crash.
Anyway, I leave both my XLs and my Mini on 24/7 honestly. They only get rebooted if I had a reason to reboot them. So I did a hard reboot of the alpha XL by power cycling it with the manual switch on the back, and the problem went away entirely and hasn’t returned as of yet. Printed two things out no problem immediately after and the next day.
Happy to add crash logs or whatever else if they would help.
Diese r Beitrag wurde geändert Vor 3 months 2 mal von Chase York
Veröffentlicht : 19/10/2025 4:59 am
Chase York
(@chase-york)
Idk, my single toolhead prints haven’t experienced this problem at all so far. Not sure if that’s standard or unique to my experience. But it would seem to me that it has some effect on the function of the printer, enough for people’s problems to be different across “models” to some extent. There’s an additional “expander board” on the 5TH model that handles the CAN bus connections to tool heads 3-5 as well, providing additional power outputs, signal routing, and sensor inputs as well. So it’s different hardware wise in that way too. But I’m no developer, lol. I’m just making assumptions here.
Veröffentlicht : 19/10/2025 5:25 am
Eric Colby
(@eric-colby)
Mitglied
Experiencing a lot of the same issues as stated above on my 5T XL. Heads crash when docking or simply fail to fully dock resulting is a crash. There is also a severe layer shift on every single print within the early layers (2-5) after correcting the docking failure. Even when performing a single toolhead print which never crashes, I also see the same early layer shifts occur. I've ruined too many prints and reverted back to 6.2.6 until it's resolved. The auto retraction and starting print features did work well and my build plate didn't look like it had chicken pox anymore, way less oozing and boogers. Very eager to try this once it's re-posted in beta.
Veröffentlicht : 20/10/2025 1:39 pm
Bdbtoys
(@bdbtoys)
I rolled back to 6.2.6. I just got docking issues when it went to drop off the print head on a single-color print last night. This release is not ready for prime-time on the XL.
Veröffentlicht : 22/10/2025 8:33 pm
1Eye
 1Eye
(@1eye)
Same. Too many issues and I'm unable to 'just print something' like I used to.
Veröffentlicht : 02/11/2025 1:23 am
1Eye
 1Eye
(@1eye)
Just rolled back as well. Fingers crossed I can get back to being able to print even the most simple things again.
Veröffentlicht : 02/11/2025 1:24 am
John Katzman
(@john-katzman)
Mitglied
Posted by: @1eye
I had no issues after rolling back, only casualty was a nozzle thankfully.
Veröffentlicht : 02/11/2025 4:04 am
Cachou
(@cachou-2)
Bonjour,
Je suis passé sur la version Alpha, même problèmes cité plus haut, j' ai tout vérifier, alignement des axes, tension des courroies, etc...
Mes courroies étaient à 77 hrz, je suis passé 82 hrz pour la tension, depuis plus de soucis, je fais des prints de plus de 12 heures sans crash, maintenant je vais testé en multi couleurs et vous tiens au courent.
MK3S+; Ender5/Matrix extrudeur
Veröffentlicht : 02/11/2025 7:01 pm
Seite 1 / 2
