6.2.4-RC1 Firmware for Original Prusa XL
Jan Kratochvíl
(@jan-kratochvil)
Mitglied Admin
Summary
  • Reduced USB errors
  • CORE One printer detection
  • Fixed returning to wrong Z position after pause
  • New print fan type [XL]
  • Improved extruder error detection [XL]
This is a public release of the 6.2.4-RC firmware for the Original Prusa MK4, MK4S, MK3.9, MK3.9S, MK3.5, MK3.5S, MINI & XL.
This is a release candidate intended for experienced users. We’ve not been translating changed/newly added texts yet. The features in this firmware are still under development and may not perform as expected. Should you encounter any bugs or issues with the printer’s performance, please report them via GitHub or in our forums.
Reduced USB errors
We fixed a rare condition that could occasionally trigger a “USB Error” pause during printing.
The firmware brings a new bootloader version 2.4.1, which is able to recognize MK4S from CORE One (based on whether the door sensor is connected).
NOTE: Before you convert your MK4S to CORE One you need to update the FW to 6.2.4. If xBuddy is already connected in CORE One and the door sensor is attached, the bootloader refuses to update. We will remind you of this in the MK4S to CORE One Conversion Guide.
When unpausing, the printer was not applying the MBL correction to the unpark move.
This was already fixed in 6.2.3, but 6.2.3 was only released for MK4 and MK3.5. 6.2.4 brings this fix to the XL as well.
We have extended our list of suppliers for print fans on the XL. The new fans have slightly different properties. Since the printer cannot automatically detect which fan is installed, we have added a settings option (Settings -> Tools Settings -> Print Type Fan) for selecting the correct fan type the printer is equipped with.
Extruder errors (extruder not spinning) should no longer trigger for parked tools.
Veröffentlicht : 10/04/2025 7:24 am
Gerald
(@gerald-6)
Bonjour
Je constate que cette version a toujours le problème de décalage de couche. J'ai spécialement effectué le tour de prise d'origine que PRUSA fourni pour vérifier la tension des courroies.
Tour de prise d'origine, avec la version 6.2.1 = aucun souci la tour est très correcte.
Tour de prise d'origine, avec la version 6.2.2 = Décalage de couche la tour est HS.
Tour de prise d'origine, avec la version 6.2.4 RC1 = Décalage de couche la tour est HS.
De plus j'ai procéder à plusieurs réglages des courroies avec la version 6.2.4 RC1, Impossible d'obtenir un tour correct, toujours des décalages de couches.
Je suis donc revenu a la version 6.2.1 et j'ai procédé de nouveau aux réglages dès la courroies, et la pas de souci tout est rentrer dans l'ordre.
Je signale qu'à chaque réglage des courroies et avant impression de la tour, j'ai procéder à l'étalonnage de la XL, (CALIBRATIONS).
En ce qui me concerne, je constate donc que sur ma XL. Il n'y a que la version 6.2.1 qui fonctionne correctement. (Pas de problème de décalage couche et pas de souci USB).
Veröffentlicht : 15/04/2025 6:22 am
