2 Head XL Multicolor
Hello,
How I change the color/filament to other then two that are already on the extruders ?
On Prusa Slicer if I select the "add color change" , there is only the two options (extruder 1 , extruder 2) , what if I want to add another spool with a difrent color ?
Thanks.
RE: 2 Head XL Multicolor
You have only two extruders right?
So two colors.
Want more… order the upgrade… or you can pause and manually swap filaments the old one-extruder way.
Yes I have only two extruders.
Yes the ideia is to manually swap filaments, but how I chose that option in Prusa Slicer ? There is any option then choosing one of the extruders ?
Thanks.
You only have two extruders so what other extruders would you be choosing from?
M600 color change just pauses the print for you do the filament swap manually - nothing else.
The choice of your two extruders is to choose which tool is active for the manual swap.
I think I know what you’re asking… there should be a pause option in the right click menu from the preview scroll bar. I don’t see it either, but it used to be there…
OK I see what it is. The pause is only there in the menu when there is only one object. Multiple objects and the menu only shows the extruders.
This sounds like a English translation issue. Extruder = print head. So just do exactly what you showed in the picture, and the printer will stop at that point to let you change filament.
Brand new to 3D printing and my 5-tool XL is my first 3D Printer!Check out my Multi-Tool fork of PrusaSlicer to mix and match nozzle sizes.
I already did the color change of an extruder with the option "Add color change (M600) for: " then choose the Extruder.
At the layer selected it pops a message to change the filament, I do a manual change of the filament, select purge, then ok, and the printer resume the job.
But in this procedure there is an issue, when I do the purge the filament, with a clamp I remove the purged filament but it don't stop to slowly extrude filament because of the head temperature. Then I resume the printing which leave a a chunck of filament all the way to the coordinates that was the color change on the print job.
There should be an wipe tower or someting like that, how I force an wipe after the purge filament and resume the print ?
Thanks
Best Regards
Hey. I have explained color swap for the mini+ here in my printables model:
https://www.printables.com/de/model/477369-amiibo-coin-box-coins
Maybe this works ob the XL too.
