Z Axis Ball Bearings
jack
 jack
(@jack-16)
Miembro
Hello,
I made a mistake when assembling my Prusa XL and accidentally let the Z Axis slide off too much and lost a few of the ball bearings in the rod.
Could anyone tell me what size ball bearings I should buy to drop into the rod to replace them? I was able to recover most of the balls and was able to re-insert them but when comparing it to the other side am still missing a few (and there is at least 1 ball that I am unable to recover).
I hear that Misumi bearings are the best ones to get, if anyone has suggestions on where to purchase them that would also be fantastic. On Misumi's site I mostly see ball bearing assemblies, not just the tiny balls themselves.
Respondido : 25/01/2024 2:31 am
j
 j
(@j-5)
Did you ever figure this out? I just had 4 come out and I'm not sure how to put them back
Esta publicación ha sido modificada el hace 2 years 2 veces por j
Respondido : 04/03/2024 4:17 pm
ThreeDeeByRusty
(@threedeebyrusty)
Miembro
RE: Z Axis Ball Bearings
Same exact problem. Except the only reason my ball bearings were past the limit is because I was trying to straighten out a crooked heat bed. Reason for crooked heat bed was due to the extreme misalignment between bearing bed bracket threaded holes and the heat bed mounting holes.
Respondido : 06/03/2024 1:13 am
Erik D.
(@erik-d-2)
@jack-15 @j-7 @threedeebyrusty I did worse, all the ball bearings fell on both sides. I had to remove the bed to show Prusa support the sag and forgot these had to be removed. Did you find out what size bearings they are and how many are on each side? Did you figure out a technique to put them back safely? I am really upset and see no way to re-assemble it correclty.
Respondido : 13/03/2024 2:58 pm
Evan Sandler
(@evan-sandler)
Miembro
STAND BACK
For the first time in my life, I'm actually going to contribute to the technical forum. I don't know what size ball bearings to use, and I'm still combing through my carpet trying to find the last 3 balls I'm missing, bit I know how to reassemble the bearings. The bearing assembly has two tracks that the balls roll through, one on either side. These tracks are circular loops that the balls actually travel around, which is why they so efficiently propel themselves out of the assembly when the linear rail is removed. The trick I figured out is to use the linear rail to hold most of the balls in place during reassembly.
First, I pressed a few balls into the tracks on both sides of the bearing assembly, then reinserted the rail. Then, I slid the rail forward until just enough of the track was exposed to let a single ball in on either side. I then took a set of tweezers and started packing the remaining balls into either side of the assembly, using the point of the tweezers to push the balls towards the rail, deeper into the ball tracks.
Respondido : 16/04/2024 3:44 pm
if you are only missing three balls, leave one out of one side of the linear rail truck and two out of the other side, and the bearings should function well.
they are not highly stressed
Respondido : 16/04/2024 4:05 pm
JARIAS
(@jarias)
Miembro
Any luck with the size/type of the bearing balls? I'll miss like 4.
Respondido : 13/05/2024 4:51 am
kenryan
(@kenryan)
If you have decent calipers to measure one, McMaster-Carr sells loose bearing balls (look under steel stock).
Respondido : 22/06/2024 3:45 am
JARIAS
(@jarias)
Miembro
Yup, I need to buy a good caliper and disassemble the block. I'll take a look there. Thanks, man!
Respondido : 22/06/2024 4:16 am
cormier
(@cormier)
Posted by: @joantabb
If you are not afraid to dismantle left and right linear guide, you can transfert 3 balls from the right Z linear guide ("rotative Z axis")  to the left Z linear guide.
Blocking the bed X rotation is fully acheived by the left linear guide. So it is better to have no missing ball on that side.
Because of the rotating bed support, the right Z linear guide don't have to withstand any torque around X.
The only function of this guide is to block Y translation, wich I think can be acheived by only one ball between the two rails off each side of that guide.
So some missing balls would have no consequence.
To @JoanTabb : I would have avoid to remove balls from the missing ball linear guide, don't you ?
Respondido : 17/07/2024 6:35 pm
I wouldn't remove bearings for fun, but I would be prepared to use a linear truck with one or two balls missing...
Respondido : 17/07/2024 9:28 pm
RD
 RD
(@rd-5)
I finally got this to work, just because the idea of being short 5 bearings was too much to take. I could not find an online example with our exact same Prusa (MGN?) rails and bearing blocks.
Every time I would put the carriage onto the rail, bearings would pop out rather than cycle through the carriage...so here is what I did.
1. Took the old linear rail and used it as a guide
2. Jammed my finger, no glove, into the carriage so that my finger was pressing all the bearings against the walls of the carriage
3. Slowly pushed the rail through the carriage
4. Failed, 3 bearings escaped, tried again
5. Got it, with the exception of 2 bearings, used some tweezers to push the other hard into the carriage, they cycled, put my finger back in there and slowly moved the rail, and it worked.
6. Placed the new rail, end to end with the old rail, and slid my carriage onto it.
7. Put those little plastic inserts into the screw holes and did not take them out until I installed the rail.
8. Lubricated the carriage with the syringe as it was a little "grabby" on the first slide.
...hope this helps, what an ordeal. I read something online that suggested that the thick grease makes the bearings resistant to cycling and more likely to pop out. Maybe this is why the online examples on YouYube worked so well.
Respondido : 06/01/2026 1:51 am
