XL 2t printing issue
glenngipson
(@glenngipson)
Membre
What is this?  What causes this and how do I correct?  Is this stringing?  Nozzles are .6 mm and filament is the Prusament PLA delivered with printer.
Publié : 03/04/2026 7:21 pm
jan.d.slay
(@jan-d-slay)
RE: XL 2t printing issue
Hey
Unfortunately, right now it's just guesswork.
  • What does the object look like “normally”?
  • How thick is your first layer?
  • Have you cleaned the print bed?
  • Is your nozzle really clean during bed leveling?
Publié : 04/04/2026 6:03 am
glenngipson
(@glenngipson)
Membre
Thanks for your reply.  I am new to this so I am definitely still learning.  The problem really developed on the 1st layer where I do not believe it adhered to the print plate and was pulled up as the nozzle moved away.
  1. This is a label for a hydroponic garden I got from printable and modified the size slightly.  See below.
  2. The 1st layer was .2 mm thick.  Subsequent layers are also .2 mm thick.
  3. I cleaned the print bed with IPA before printing
  4.  The nozzle appeared to be clean but it may not have been.
Since originally posting I have now had my Prusament PLA filament in my dehydrator at 40C for approximately 8 hours.  Nozzle temp on 1st layer was 230F and on subsequent layers 225F.  I plan on lowering these temps to 215F and 210F respectively.  What do you think?
Publié : 04/04/2026 7:42 pm
1 personnes ont aimé
I suspect the part is not well designed for 3D printing - however: save your project as a .3mf file
Files > Save Project as
Publié : 05/04/2026 1:47 am
Juzam
(@juzam)
IPA is not enough sometimes. Clean the bed with warm water and dish soap, dry it thoroughly and try again. Also satin sheet is not the best with PLA. Get a smooth PEI sheet.
Publié : 05/04/2026 10:58 pm
jan.d.slay
(@jan-d-slay)
I would use the 0.4mm nozzle and reduce the first layer to 0.15mm or less. With such a small surface area, the first layer needs to adhere really well to the bed. I would also reduce the speed again if it’s going too fast.
Publié : 06/04/2026 7:49 am
