Very messed up first layers with particular print
Jake
 Jake
(@jake-15)
I just got my XL yesterday, did a test print that came out great, then designed something to test out printing with all 5 extruders. I've spent all day fiddling with  PrusaSlicer and the printer and I just can't get it to print. Here's the first and second layer on my 10th failure:
First and second layer after another print failure
I can't figure it out. The issue in the last few has been a first and second layer that look like that, then the third layer collides with the second. I did another test print (a disc a few layers thick) using just that particular extruder and PLA and the result was perfect, which is why I'm so confused:
Test print first layer
I've pretty much stuck to the default slicer presets (I've tried a couple) and I don't think there's anything particularly unusual about the model:
Cute little lime guyFirst 2 layers by feature typeFirst two layers by colour (all same colour)
Any ideas? Thanks
Best Answer by Marc:
Have you done the Tool Offset Calibration? See Step 18 and following https://help.prusa3d.com/guide/5-first-run_482742#483292
Napsal : 20/08/2024 1:00 am
Jake
 Jake
(@jake-15)
RE: Very messed up first layers with particular print
Small update: disabling phase stepping helped a lot with the gaps, but it still seems to try and print into the same layer or lower causing collisions:
First few layers with phase stepping disabled
Could it be an issue with z calibration across different extruders?
Napsal : 20/08/2024 9:31 am
Marc
 Marc
(@marc-9)
Napsal : 21/08/2024 8:40 am
Jake
 Jake
(@jake-15)
Posted by: @marc-9
Yep, that solved it. I think something must have knocked out the alignment after the initial calibration, then my second go the nozzles probably weren't properly clean. Heating each head up to 250 for five minutes then cleaning and recalibrating got it working nicely.
Napsal : 21/08/2024 7:38 pm
ssmith a Marc se líbí
