Print fan rpm test failing (yes, I searched and see all the other posts)
I found the other threads about this common issue, but I'm not sure if I'm having the same problem. I took the shrouds off, and 4 of 5 consistently pass, but one fan just doesn't start. If I give it a push, it will go, but without a push, I can see it twitch a few times, but it will never get going. I took it completely out of the housing and got it going pretty fast with some air, but that didn't help either.
This seems like it's just a bad fan, but want to do a sanity check...thanks!
Opublikowany : 04/01/2026 7:18 pm
