Nozzle Heater Test fails on Toolhead 3 and 4 sometimes
JohnnyT
(@johnnyt)
Nozzle Heater Test/Preparing and Heater testing can fail on 3 & 4, especially when all five nozzles start cold.  Should I be concerned?  Or is this just a firmware bug?
Thanks, JT
Respondido : 18/11/2023 2:35 am
JohnnyT
(@johnnyt)
RE: Nozzle Heater Test fails on Toolhead 3 and 4 sometimes
BYW, using fw 5.1.0-alpha2
Respondido : 18/11/2023 2:57 am
Nikhil S.
(@nikhil-s)
Have you tried the latest release firmware? Based on a few recommendations I got, when my XL5T arrived this week, I did the hardware assembly and then immediately flashed the latest firmware.  Everything went smooth and easy, with the only exception being the fan test which I had to run twice, but that took only 10 seconds or so.
Brand new to 3D printing and my 5-tool XL is my first 3D Printer!Check out my Multi-Tool fork of PrusaSlicer to mix and match nozzle sizes.
Respondido : 03/12/2023 10:44 pm
Russell Pirlo
(@russell-pirlo)
I have been getting intermittent heater test fails, its especially difficult with 5 heads they all must be retested if one fails, then one passes and another fails. I thought it was hardware, replaced some of the thermistors and even full hotends, still getting intermittent problems. I have not found a solution, but I have wasted a fair amount of time and money change thermistors.
Respondido : 06/06/2024 5:42 pm
Jeff
 Jeff
(@jeff-16)
I see this intermittent failure on my 5 head XL as well. An immediate repeated test will pass. I have seen this on 6.1.3 as well as the current 6.2.0 alpha 2. Do others see this? Any resolution?
Respondido : 15/10/2024 11:24 am
