Missing layer line or thicker layer
viking
(@viking)
A problem I have been having, seems to be on most prints now.
I'm having this strange issue which I think is not a layer shift.  Sometimes a part of layer is missing, sometimes it seems like the filament squeezed out thicker.
It's most often happening at roughly the same height from approx 30-60mm. Have printed full height, but after the problem  "zone" it prints perfectly.
Respondido : 30/09/2024 10:04 am
replica3d
(@replica3d)
Miembro
RE: Missing layer line or thicker layer
Same issue here.
Respondido : 10/10/2024 11:11 am
Jeff
 Jeff
(@jeff-16)
I'm also seeing this. It appears to be associated with just my second tool head. I initially thought it might be a partially clogged extruder so I did several cold pulls, but the problem persists. This morning I swapped out the extruder for a new one. We'll see if this helps or not. I'm not optimistic because after removing and carefully inspected the older one, it looked perfect.
Respondido : 11/11/2024 3:35 pm
kmdtcs
(@kmdtcs)
Miembro
I've had this same issue as well. My assumption was that the z-axis is skipping or doubling up on a layer. It's not a consistent problem though so it's hard to troubleshoot. I've also only seen it on higher z heights which makes it even harder to trace down.
Respondido : 13/11/2024 6:22 pm
MalsBrownCoat
(@malsbrowncoat)
Can each of you chime in with how you sent the file to the printer?
Using Prusa Connect or by manual USB transfer?
Respondido : 05/12/2024 11:33 pm
CUKIO34
(@cukio34)
im having a similar issue where my second layer in tool head 1 is not extruding. The first layer lays perfect. 2nd layer the tool head does not extrude, it picks back up half way through the 3rd layer. Im using a usb transfer.
Esta publicación ha sido modificada el hace 1 year por CUKIO34
Respondido : 18/12/2024 12:39 am
