How do Temp Towers work?
Agkirk
(@agkirk)
I don't understand how Temp Towers work as the G-code doesn't seem to increase the hot-end temperature as the tower height increases.
Opublikowany : 23/10/2023 5:16 pm
xilni
(@xilni)
Temp towers work by either providing you a 3mf project file, gcode or do it yourself where there are temp changes programmed into the layer change every centimeter for example. So the sections are printed at different temperatures. A stl file is merely a model and will not contain custom gcode temp change commands, usually a M104 or M109 command.
Opublikowany : 24/10/2023 8:11 pm
Agkirk
(@agkirk)
RE: How do Temp Towers work?
Thanks That helps.
Opublikowany : 25/10/2023 9:53 am
