Filament stuck issues.
Brand new 5 head machine.
ran through all calibration tests twice. No major issues. Try the first print: the included benchy on tool 1 with the included Prusa filament on a well cleaned bed.
layershift error just below the first deck outer edge overhang. Happened after I had to fix a “filament stuck” error. Otherwise finished OK.
Second try: assume a similar error but print did not stop or alert, benchy just not printed above about the same layer height as the layershift on previous.
Third try: checked the filament spool and feed: looks ok. Reclean the bed. Reprint but sit on it like watching a pot boil. Prints ok, no issues except not quality I expected.
try the pug from the test files: repeated “stuck filament”. Like 5 times in 15 minutes.
abort print and re-do the load cell tests on all toolheads. All pass.
try again the pug. No issues after 15 min so I leave it go. Come back when done: left front leg is spaghetti but otherwise rest of print fine.
try the test knight helmet: fine first 10 min so leave. Come back: layer shift again about same height as previous benchys, then a new filament stuck error.
i looked on the Prusa site for loadcell fixes and they show how to loosen certain screws, but not for the multi-tool head.
any help?
Bit of rant below so feel free to skip.
I’ve been printing FDM and Resin four about 4 years. Started (FDM) with the ender 3 v2, then an Elegoo Kobra Max. So I am used to tinkering. But….I HATE tinkering. I do not enjoy the 3D printer engineer hobby. I want to print neat/useful stuff.
I got a Bambu X1 carbon before I realized the shittiness of the company and will never buy another of their products. I bought the xl multitool to support a Good company.
(you’ve probably guessed where this is going next) But as shitty as Bambu is the damn printer JUST WORKS. I have not had to screw with it to get good prints.
Im willing to deal with some tinkering. But for what I paid for this thing that “some tinkering” is gonna hit a limit.
RE: Filament stuck issues.
try to install 6.2.6 firmware if you don't an repeat all the calibrations
I’ll have to look into just shutting it off.
thanks.
I’m at firmware 6.4.2
so I should try an older version?
Yes and repeat the calibrations
I’ll give that a shot.
thanks.
For all issues with a new machine or newly built kit the best resource is Prusa Support via chat. You will need the serial number of your printer.
Thanks for the heads up!
I’ll check there as well.
