Filament Calibration Fail
Just completed the build and I am running through the calibration steps. When I attempt to run the filament calibration, it reads the first sensor just fine, but I get no response on the second. Apparently, I need both to pass the test.
When I select to run the test on Tool 2, the XL exchanger switches to Tool 2, then allows me to run the calibration test. When I insert the filament in the first slot, I get no response. However, when I insert the filament in the second slot, the display shows a reading on Tool 1.
Any thoughts on how to fix this? I have doubled checked my cabling.
Napsal : 27/10/2023 3:26 am
