Gradual Layer Shift
muddler13
(@muddler13)
Gradual Layer Shift
Looking for recommendations/suggestions for the cause?
Setup:
Prusa XL 5T  Firmware 6.26, with PLA,
Cylinder is aprox. 150mm dia.,
Total height of model is 220mm, it never gets that high.
.20 HF noz. using profile that uses the Prusa slicer Speed Profile
I have re-calibrated multiple times, Checked for loose grub screws on the pulleys (all tight). Haven't checked Belt tension with app but they do not appear to be loose. Will check belt tension as soon as current test print which is printing a "Structural" speed.
Napsal : 07/10/2025 12:08 am
