Multiple failures - Please help.
dmbgo
(@dmbgo)
I have been trying to print an oiler block for my lathe. I am finding it tricky to say the least. I'm printing the block on a compound angle because it has multiple tubes inside and I think it needs to be like this to help keep the bent tubes inside clear. I'm using Sunlu PETG filament. I have tried about 4 times now, but it keeps ending up as a rats nest :). Ihave 2 x printers, an Xl and a Core One, but have had the same negative result on both printers.
Napsal : 13/08/2025 11:03 pm
dmbgo
(@dmbgo)
RE: Multiple failures - Please help.
I have now solved the problem after a call to support, I ended up just including some supporting structures in the cad file.
Napsal : 14/08/2025 3:29 am
