SOFTWARE FIRMWARE NOOB ERRORS
Redshift Z8
(@redshift-z8)
Hello please can you tell me when you going to release an update that fix this incredible machines terrible software.     I have multiple xl's   and honestly unless you fix this software you will be getting them all back.
What is utterly unacceptable is the fact the machine seems to FORGET there is a extruder loaded onto the machine and then tries to ram it into another docked extruder/head.    I mean WHAT IS GOING ON this is a ridicules thing to happen after the machine has been out this long.   This is the sort of fault you expect to be fixed in the first weeks of a machines launch.
IF YOU CANCEL A PRINT HALF WAY THROUGH, THEN CLEAN THE BED AND START A NEW PRINT THE MACHINE JUST RAMS WHATEVER HEAD IS ON INTO ANY OTHER HEAD WITH SUCH FORCE IT MIGHT DAMAGE SOMETHING.
Why does it forget its already homed itself on occasions where it should not have.    Sometimes the homing simply has a total meltdown another rooky error.   The last update lead to loads of people getting extruder not spinning error with a frankly terrible write up on the cause and the solution, that write up frankly made little sense to a majority of people and my 10 year old could have done a better job.
FIX the dam screen on the machines which after a long session just go black.    Dont say its a hardware issue because it happens across all 5 xls that i have.
I mean seriously what is going on at prusa to make the flagship machine still have these stupid errors that are so obvious and should have been picked up straight away in testing new version releases.
Come on Prusa   get these basic things right !!!!!!!!!!!     I would like a response from PRUSA on this errors.   No wonder people are buying mass produced bamboos in droves.     Its not good enough.       If you need to hire people to get this software correct then do it !!!!!!
Opublikowany : 06/07/2025 9:38 am
Redshift Z8
(@redshift-z8)
RE: SOFTWARE FIRMWARE NOOB ERRORS
WHATS EVEN WORSE IS IF YOU CANCEL A PRINT HALF WAY THROUGH, AND THEN TRY TO DOCK THE TOOLHEAD TO AVOID THIS PROBLEM THE MACHINE FORGETS ITS BEEN HOMED AND TRIES TO HOME AGAIN SMASHING THE THOOLHEAD INTO TOOLHEAD NUMBER 1.
I mean come on prusa, i run a a business here and if i had employees that programmed this stuff in they would be fired.   Its utterly unacceptible on your flagship machines.
Opublikowany : 06/07/2025 9:47 am
