Looking for Prusa XL assembly tools
Hi - I purchased a used Prusa XL 5 tool off ebay but it didn't have the original assembly tools included with the kit - is there someplace I can purchase this? Thanks in advance for your help.
Opublikowany : 06/12/2025 3:47 am
The only hard to find tool is the torque indicator but you can print that: https://www.printables.com/model/449554-xl-printable-parts/files
- Look under 'Others'
But it might be easier to use a conventional torque head - the values are in the comments on the build manual iIrc.
Otherwise many makers will already have everything: a set of metric allen keys and metric spanners, narrow nosed pliers and a torx screwdriver.
Look through the construction manual where you will find everything you need is listed.
Opublikowany : 06/12/2025 6:58 pm
