Prusa XL 24v output ???
MME
 MME
(@mme)
Hey everyone I am about done with my enclosure and will be installing a Nevermore V6 air circulator/ air scrubber. My question I need a 24v supply and cannot find a wiring diagram anywhere for the XL.
         Does anyone know if there is a 24v supply that I can wire the Nevermore V6 too? It will also have a inline external switch to turn it on and off.
Thanks ahead of time. Mark
Best Answer by René:
You could make a 24V tap at this point.
Opublikowany : 17/10/2023 7:10 pm
René
(@rene-3)
RE: Prusa XL 24v output ???
Opublikowany : 18/10/2023 7:36 am
1 ludzie polubili
Thejiral
(@thejiral)
Alternatively, you can find those 5015 blowers, needed for a nevermore also for 12V, if that makes it easier.
Opublikowany : 18/10/2023 9:17 am
1 ludzie polubili
MME
 MME
(@mme)
I actually found a power supply for it. I added a hour meter to the power strip so I can track the hours for media replacement.
Opublikowany : 31/10/2023 9:43 pm
CleverSquirrel
(@cleversquirrel)
Do you know how many amps the 24v supply is at this point?
Opublikowany : 31/10/2023 10:06 pm
MME
 MME
(@mme)
Posted by: @cleversquirrel
The power supply is 24V 2.5A
The air scrubber is less than that. I will check tomorrow to see if the meter shows amps. I don't think it does.
Opublikowany : 31/10/2023 10:33 pm
CleverSquirrel
(@cleversquirrel)
Sorry - missed that you’d replied! Thanks so much for testing this out for me - very much appreciated!
Opublikowany : 07/11/2023 9:44 am
1 ludzie polubili
MME
 MME
(@mme)
Sorry it took me a while to get back. The hour meter does do amps. I keep the Nevermore air scrubber plugged into it for the hours.
The Nevermore is drawing .077 amps using the 24v power supply.
Opublikowany : 08/11/2023 7:03 pm
1 ludzie polubili
bwschulz
(@bwschulz)
I'm trying to get 24V from there for a similar air cleaner project, but I'm getting no voltage at all. Printer works fine, but I'm getting nothing from those posts. Is there a switch or jumper I need to enable or something?
Opublikowany : 19/10/2024 4:09 pm
