Prusa XL 24v output ???
Hey everyone I am about done with my enclosure and will be installing a Nevermore V6 air circulator/ air scrubber. My question I need a 24v supply and cannot find a wiring diagram anywhere for the XL.
Does anyone know if there is a 24v supply that I can wire the Nevermore V6 too? It will also have a inline external switch to turn it on and off.
Thanks ahead of time. Mark
RE: Prusa XL 24v output ???
Alternatively, you can find those 5015 blowers, needed for a nevermore also for 12V, if that makes it easier.
Do you know how many amps the 24v supply is at this point?
The power supply is 24V 2.5A
The air scrubber is less than that. I will check tomorrow to see if the meter shows amps. I don't think it does.
Sorry - missed that you’d replied! Thanks so much for testing this out for me - very much appreciated!
Sorry it took me a while to get back. The hour meter does do amps. I keep the Nevermore air scrubber plugged into it for the hours.
The Nevermore is drawing .077 amps using the 24v power supply.
I'm trying to get 24V from there for a similar air cleaner project, but I'm getting no voltage at all. Printer works fine, but I'm getting nothing from those posts. Is there a switch or jumper I need to enable or something?
