Warping and layer shifts
Dario
(@dario-2)
I printed some custom case, upper and lower part separately:
As you can see on the second image upper element warped, so did the lower but not so much. Also on the first image you can see some layers shifts, don't know how an SLA printer can produce layers shifts...
What to do to improve print quality?
Postato : 06/09/2019 8:04 pm
Dario
(@dario-2)
RE: Warping and layer shifts
I'm now trying with 10 sec exposure times instead of 7.5, will see if that helps.
Postato : 07/09/2019 9:10 am
patrick.v2
(@patrick-v2)
I have the same issue printing a rectangular box (40x30x10mm). I used the presets for PRUSA tough azure blue 0.1mm, used the "optimize orientation", support everywhere and pad below object. Still the rectangular box is not quite rectangular, planar surfaces show slight deformation and some sides are not quite square to other sides. It's not much but can be directly seen.
Any hints ?
Postato : 01/10/2019 7:11 am
patrick.v2
(@patrick-v2)
update:
I upgraded the firmware of the SL1 to 1.2.2 and made the part hollow (Meshmixer, default values) and it's much much better.
Postato : 01/10/2019 1:46 pm
Dario
(@dario-2)
I had much better results with gray resin than prusa orange resin, but still not perfect, will try with new updated firmware
Postato : 01/10/2019 5:42 pm
