SLS1 adding extra base and supports to bottom of all models
I am new to using the SL1S and am having issue with the slicer adding extra base and supports to the bottom of the model. They STL appears flat and i tried ensuring it was a clean base and even recut a few of them.
Am i doing something wrong in the slicer or is it a model issue?
Best Answer by Lichtjaeger:
You just need to activate the pad option "Around object" or deactivate supports completely. This will deactivate the object elevation.
Veröffentlicht : 11/09/2021 5:06 pm
Default object elevation is 5mm
Veröffentlicht : 13/09/2021 9:47 am
