SL1S Speed prints with wave/line/deformed
jem
 jem
(@jem)
Hi everyone!
I'm having issues with prints from SL1S Speed.
Using the Prusa Azure Blue Tough Resin and it shows lines on the prints.
Using Anycubic Plant-based UV Eco-Resin(CLEAR), there are lines, deformation and there was 1 that did not print out properly and was sticking to the FEP.
I'm using the Prusa slicer default settings for SL1S Speed when printing both resins.
Layer height: 0.05mm
Exposure time: 0.2s
Initial exposure time: 25s
Is there a way to get rid of the lines of the print?
How to print the clear resin without any deformations?
Thank you!
Opublikowany : 16/06/2022 8:58 am
Todd @ Figure Forge
(@todd-figure-forge)
RE: SL1S Speed prints with wave/line/deformed
0.2s exposure is awfully short. Was that a typo?
If so, then the issue is likely to do with flexing on the supports which is causing shifts. Make your support stems thicker generally or use some larger anchor supports. In particular, think about supporting on the sides of the model to stop and lateral movement.
Opublikowany : 20/06/2022 6:27 pm
jem
 jem
(@jem)
Ah, that's a typo!
Here's my layers and exposure time:
I was using these settings for the supports:
I'll try to adjust the supports with the suggestions. Thanks for the reply!
Opublikowany : 21/06/2022 12:55 am
Ben Marshall Designs
(@ben-marshall-designs)
seems the model is shifting b/w lifts. Perhaps adding some supports where those shift lines are might help?
Opublikowany : 29/12/2023 6:24 pm
