Problem starting printing
ilserominaa
(@ilserominaa)
Hello, i have a prusa i3 mk3s and i just mounted all the components and i runned the selftest, it looks all is ok. When im going to start printing form a SD folder... first, it's nivelate and then when is starting to print, goes to the center and ask to take out the filament manually and put it again, then it goes back to reanude the printing, and again the same problem, go to the center and remove the filament. Whats the problem? should some wire cable connected wrong? is the only thing that is not working.
Please help!
Posted : 26/03/2020 12:45 pm
MikeH
(@mikeh)
RE: Problem starting printing
This forum is for the Prusa SL1 and you might have better luck on one of the Prusa FDM forums.
Posted : 26/03/2020 7:02 pm
