Mixing prusament?
Pschne
(@pschne)
Mixing prusament?
I see that there are several topics on mixing resins already so i guess it can be done but has anyone experimented a bit with ratios? Has anyone tried mixing prusament tough with Prusament flex80? How do you adjust print settings for compensating for the mix? My goal is just a print that is a bit less brittle. I only have experience with the old prisa tough resins, are the new Prusament resins less brittle? I especially have problems with the prints cracking when using any type of screws to assemble models
Thanks in advance
Respondido : 14/03/2023 2:20 pm
MikeH
(@mikeh)
RE: Mixing prusament?
If you haven't aleady tried, using a tap to pre-thread the holes should work much better than using the screw itself to form the thread.  For though holes, you'd want a spiral point (gun) tap; use a spiral flute tap for blind holes.
Respondido : 16/03/2023 1:01 am
