Minimum wall thickness?
I am considering the SL1 for a particular series of prints, which include rather thin vertical walls. So far I have not been able to any guidelines which relate to how thin such walls could be reliably printed. The part is not exactly a box, but the challenging features are the vertical wall, so for illustration I would say consider a box which is 2 x 2 x 2 cm, with the bottom of the box a bit thicker, maybe 1 mm or so, and there would be no top of the box printed. In that scenario, how thin could the walls be reliably printed? Ideally for my needs that number would be 0.3 mm or a bit less. Any advice or thoughts are greatly appreciated!
Opublikowany : 20/11/2020 6:25 pm
