Drainage hole diameter maximum?
I really like to print a massive drainage hole on the bottom of hollowed model bases, that is not quite as big as the base but close to it.
Since the base of a model is flat on a table at any given time, it's no issue aesthetically to effectively remove the entire base inside the rim, and it makes large hollow bases a lot easier to clean, support, and print. Plus saves a good chunk of material. - You get the picture.
The issue I'm having is that the maximum drainage hole size I am able to make in prusa slicer seems to be 60mm.
Is there any way to increase that? Is there a max setting somewhere that I haven't been able to find?
Thanks for any insight you may have.
Napsal : 21/03/2023 2:48 am
