Deformed parts
Guys, I'm having a problem with some printed parts that have been deformed, has anyone seen something similar? I'm using low resolution and Prusa resin, white. Any configuration to be done? Any recommendations on the position of the pieces on the table?
thanks
Opublikowany : 17/01/2022 6:11 pm
RE: Deformed parts
Seems like the model weight is deforming b/w peels? Have you tried hollowing the model (if possible), also adding some supports to reinforce the heavier portions of the model. Also, have you tried reorienting the model?
Opublikowany : 29/12/2023 6:27 pm
