Anycubic clear resin
pavel.s15
(@pavel-s15)
Hi.
Someone tried to print Anycubic clear resin on SL1 ?
I need you experiences with cure time.
Thank you
Veröffentlicht : 13/12/2019 10:14 am
Nino Nobile
(@nino-nobile)
Mitglied
RE: Anycubic clear resin
Hello,
I was trying to print with the transparent resin of Prusa with the preconfigured times and the result looks yellowish, I really thought it was going to be clearer.
I was thinking about trying to reduce exposure times but I'm not sure.
Veröffentlicht : 21/01/2020 8:37 pm
AndyInSwindon
(@andyinswindon)
@nino-nobile
I've used the Anycubic clear on my Elegoo, and it does cure with a yellowish tinge on there too, a lot of people have noted the same.  What exposure settings are you using for it on the SL1?
Veröffentlicht : 21/01/2020 9:02 pm
Nino Nobile
(@nino-nobile)
Mitglied
@apromain
I have been using the specific configuration of Prusa, 7s of exposure time, I have not had time to test increasing or decreasing it.
What configuration were you using?
Veröffentlicht : 22/01/2020 3:19 pm
AndyInSwindon
(@andyinswindon)
@nino-nobile
I was using an initial cure time of 60s for 5 layers, with 8s per layer thereafter.  Might be a bit too high.
Veröffentlicht : 25/01/2020 2:16 pm
