A print keeps failing. The model keeps sticking to the FEP foil instead of the build platform. I added a ton of support but it doesnt fix it.
Could someone give it a try and slice it?
https://www.mediafire.com/file/h2o9jh478kkta6s/G9x_UL_top_resin_v3.stl/file
If you can save it as project file so that I can take a look at it before printing, that'd be awesome!
Thank you so much. I tried about 8 times.
Respondido : 15/09/2019 6:26 pm
RE: A print keeps failing. The model keeps sticking to the FEP foil instead of the build platform. I added a ton of support but it doesnt fix it.
Have you tried to right click and "Optimize orientation"?
Respondido : 16/09/2019 5:11 pm
