Z Axis Stepping & Advanced Setting
Xulkal
(@xulkal)
Got my SL1 pre-assembled Monday and ran a test print on it. It looks like the z axis stepping is off slightly stretching out about 1mm every 1cm. Any way to adjust the stepping of this axis from the front panel?
Also anyone able to find documentation about what all the options in Advanced Settings do? Provided manual doesn't cover them.
Opublikowany : 02/10/2019 10:10 pm
Xulkal
(@xulkal)
RE: Z Axis Stepping & Advanced Setting
Z stepping was may fault. Didn't fully cure it correctly and it was still rubbery, natural light cured it while it was skewed.
Opublikowany : 03/10/2019 1:03 pm
