Very occasionally: no print whatsoever (SL1S)
Rob Meades
(@rob-meades)
I've had this happen twice now with my SL1S (upgraded from an SL1 a few months ago): everything appears normal but, when the print completes, there is no print.  Nothing whatsoever has solidified, either on the print plate or in the reservoir or on the film, absolutely nothing, I have a reservoir of liquid resin and a damp print plate, that is it.   It is like as if the UV light never came on; no alarms, nothing untoward, just no solidified resin.  Run the print again, no movement of anything, and the print is fine and dandy.
According to the system log I have done 282 prints (I'm assuming the count is since upgrading) and this has happened twice.  When it happened today it was on an occasion when I had not quite put enough resin in the reservoir: I had cancelled the print job and then pressed reprint after filling the reservoir up properly.  I can't say whether the previous occasion when this happened was under the same set of circumstances, since this occurs relatively rarely (I was just finishing off a bottle).
It feels to me like a FW bug (I am on FW 1.8.0).
Has anyone else experienced this?
Napsal : 17/04/2026 2:29 pm
