UV Led Temp Error (thermistor and connector appear to be good)
[Risolto] UV Led Temp Error (thermistor and connector appear to be good)
Adeno
(@adeno)
Upgraded my SL1 to SL1S and have come across this weird error the thermistor I believe is right reading 107KOhm which is very similar to what came off the original UV board when I checked. The connector is fine (spent ages on that as I thought it may have been a break in the cable when I bent it) but got a bread board to break it out when I connected the system to the bottom control board and nothing changed. Kept the multimeter on the breakout break board during bootup and the system reads 3.81V not sure if that the expected voltage or not as this is the first time I've done that.
Now the really strange part if I swap out the new screen for the old error goes away, very annoying error especially since I have some work prints I need to do (might have to just swap the new screen out and use the old which still has some life in it and go to a slower print setting). Any ideas would be greatly appreciated as I'm completely confused fyi its running on 1.7.0
Thanks
Postato : 29/08/2022 10:48 am
Adeno
(@adeno)
RE: UV Led Temp Error (thermistor and connector appear to be good)
Just an update for all, with help from the Prusa team thanks Pedro and Jakub issue was components weren't found, downgraded from 1.7.0 to 1.6.6 and bingo saw screen never saw before recognizing the sl1s components issue fixed, so if anyone going forward has this issue try reflashing firmware to a previous version worked for me 🙂
Postato : 29/08/2022 2:09 pm
