Touchscreen stuck in some kind of loop...
kgbengt
(@kgbengt)
Membre
I just got the SL1S-printer for my workplace and have successfully printed some parts, but now it won't work anymore..
When i try to start a new print, the display start to loop through 3-4 menus and i cant do anything but shut off.
I've done factory reset and start-up calibrations and it seems to work, but as soon as i try to print a file it starts looping again.
Anyone got an idea whats happening?
Publié : 15/12/2025 1:16 pm
kgbengt
(@kgbengt)
Membre
RE: Touchscreen stuck in some kind of loop...
After further trying and testing i found that if i just use usb for printfiles it works. As soon as i connect the printer to Prusa Connect and send a file the problem starts. I can start the print but after a while it starts to loop through menus again. However it stops looping when i disconnect the network cable. If i unregister the printer from Prusa Connect i can connect the network cable without it starting to misbehave. I suspect it's some problem with Prusa Connect but i don't know how to fix it.
I suspect there is no one from Prusa that checks this forum but i can't find another support channel. Pretty bad for a 2k printer.
Publié : 14/02/2026 6:45 am
mnentwig
(@mnentwig)
Does the resin printer support  PrusaLink? On Core One, I stopped using PrusaConnect, as it adds no benefit (to me) just problems when it doesn't work. PrusaLink stays within my local network. I still keep the printer online so I can monitor remotely.
Publié : 14/02/2026 12:08 pm
kgbengt
(@kgbengt)
Membre
Hi, thanks for your reply!
I think it supports Prusa Link, i will try on monday!
Publié : 14/02/2026 2:00 pm
