[Resuelto] Tilt homing problem - unexpexted reason
cztokan
(@cztokan)
Miembro
Hi , I'm today solve one problem and want share an experience. Our printer stop print during printing with an error #10101 - Tilt homing failed. I do everythink from help but not working. The problem was an optical sensor of position of a connecting rod. A blade of sensor trigger was on left side of a sensor gap. After removing the sensor I see that one side of the gap is rub down and the sensor was damaged. I borrow an optical sensor from my colleague with MK3 printer, print a new housing for SL1S, mounted and it run now correctly.
Optical sensor damaged
Best Answer by cztokan:
Este debate ha sido modificado el hace 3 years por cztokan
Respondido : 02/08/2023 10:45 am
