Tilt home fails at start of a print but not from the control menu
nate.w3
(@nate-w3)
Hi there,
I have just come across a strange tilt home problem and hope someone has some insight into a cause or at least a direction to point me in.
The problem:    When a print is started the tilt fails to home causing the print to fail to start.  This is a new phenomenon as the printer has reliably printed for about a year now.  The head scratcher is that the tilt will home just fine if done from the Control menu, and if you do a machine recalibration.
Is there a difference in the tilt homing routines that could cause this difference?
Thanks in advance for any insight.
Nate
(SL1 kit with the latest firmware onboard)
Publié : 07/09/2020 7:19 pm
